Do older fountains have bad gas tank problems >
Old 02-22-2009 | 12:55 PM
Registered User
Default Do older fountains have bad gas tank problems
Im looking at a 89, 33' Fountain. Thay want 25000k for the boat. But I am worried about the fuel tanks. Either way what do you think about the price.
sdrockslangers is offline
Old 03-01-2009 | 12:55 PM
H2Xmark's Avatar
if the boat has fiberglass tanks i would pass, to convert to alumn. would cost a lot of money
H2Xmark is offline
Old 03-01-2009 | 02:03 PM
I am just about finishing the restoration on my 88 10 Meter. I haid it laid up since 1996, long story. It has 52 original hours. My mechanic tested the tanks for leaks, checked out just fine. Have them pressure tested, and if they are good, I would redo the boat.
FOUNTAIN10METER is offline
Old 03-02-2009 | 01:26 AM
10x's Avatar
10x
10x
I never heard of fiberglass tanks except for in the Skaters. I do know that the factory told me years ago, that some of the older boats had some fuel tank issues. Fountain had the tanks made from an outside source untill the early 90's. Then they started making them in house, and once they did that, there were no more fuel tank problems. It's not that expensive to replace them if you do it yourself, but it IS a big project.
Fountain powerboats rule "The Preacher"
Chicago Powerboat Club Director
[email protected]
www.chicagopowerboat.com
10x is offline
Old 03-02-2009 | 06:21 AM
Some late model Activators had fiberglass tanks with problemsSo far I've not had none
PARADISE ISLAND is offline
Old 03-02-2009 | 07:20 AM
Any pics? Whats the story?.....
senzaspectre is offline
Old 03-02-2009 | 08:07 AM
Wahoo ATV's Avatar
Racer
Pressure testing a fiberglass tank will most likely tell you nothing. If the tank is leaking, they normally have very small pin holes and the fuel leaks into the coring of the boat. If the area around your tanks is not painted you can usually see discoloration in the coring. If it is painted smell around and maybe take small core samples. You can coat the inside of the tanks with Ceram Kote to seal them if the core is not damaged.
Wahoo ATV is offline
Old 03-02-2009 | 08:45 AM
10x's Avatar
10x
10x
Wow, did'nt know that. I thought Skater was the only company that built the tanks into the boat.
Me bad. LMAO
[email protected]
10x is offline
Old 03-02-2009 | 07:47 PM
I have pictures of the 88 10 Meter, but not on a disc. My friend has a new 42 mTI and he just loves my boat. Thinks I should put it in hot boat. I have to finish the cockpit, Joey Griffin just dialed in my carbs, Will take pics and post most likely in April. I bought it in 1996 with 48 hours on it. Went through a divorce and some other issues, so had it laid up. Perfect hull, no hook or anything. Carbon fiber, new 540s, paint, complete. I think Reggie would be amazed by the boat.
Old 03-11-2009 | 03:26 PM
I have an older 81 model 33. I replaced both tanks myself about 10 years ago. Like a few others I did it myself. It was alot of work cutting the floor out and removing the tanks. Glad I did it when I bought it. Still got it, Ive spent alot on it but just love it !!! great boats !!!
Dan74 is offline
fantastixvoyage
13
05-24-2007 10:57 AM
Back4More
11-15-2006 04:32 PM
Wobble
34
05-04-2005 03:08 PM
Laktrash
6
07-01-2003 06:49 PM
