Bravo XR Service?
Old 02-22-2009 | 04:08 PM
Default Bravo XR Service?
I have a 353 Fastech with 500s, XR's and extension boxes. I purchased this boat at the start of last year, and the previous owner stated that he used Amsoil in the drives. My question is in regards to maintenance. What maintenance needs to be done in order to effectively service the drives at the start of this season? Is it just a simple change of Amsoil? Or is there more to it? I am trying to decide if I am going to do it myself, or have the work done.
GrandLake353 is offline
Old 02-22-2009 | 04:28 PM
i would check the magnets top and bottom . if there is a litle bit of metal fuzz on them that is ok , but if there are chip's or flake's then i would have them gone threw .
my 2cent
mike
mikebrls is offline
Old 02-22-2009 | 04:35 PM
Pull both oil plugs and inspect for pieces of metal. Like was said, fuzz is ok.
Drain lube.
Refill Lube by pumping it in from the bottom.
Reinstall top plug.
Grease gimbal bearing.
Grease coupler and U joints.
Griff is offline
Old 02-22-2009 | 05:28 PM
Thanks for the info. This sounds like a job that I will pay to have done.
Old 02-22-2009 | 09:22 PM
Vinny P's Avatar
I hate the winter!!
You should pull the drives and grease the u-joints.
Vinny P is offline
Old 02-23-2009 | 05:51 PM
sleek1's Avatar
Every 300 hours or 3 years is what my manual says. I just got done doing mine. Everything looked great, but I did have a lot of dried/hard spline grease on the shaft and coupler splines.
sleek1 is offline
Old 02-23-2009 | 07:24 PM
For the time it takes I do them every season. 300 and 3 years just seems way to long to me , but what do I know.
Jeff P31 is offline
Old 02-23-2009 | 07:41 PM
excursion's Avatar
I am with you, I pull mine every winter and inspect the gimbal bearing and u-joints, Tear down the complete drive every other year and swap drives every winter from port/starboard.
Better safe than sorry....
excursion is offline
Old 02-25-2009 | 09:49 PM
sleek1's Avatar
Why do you swap drives from port to starboard every other year? Not trying to be a smart arss, I just have never heard of this.
sleek1 is offline
Old 02-26-2009 | 01:22 AM
CB-BLR's Avatar
Chris
So that the teeth wear evenly... They rotate in oposite directions. Swapping sides gives even wear to both sides of the gear faces.
Chris
CB-BLR is offline
