Prop Slip Formula >
Prop Slip Formula
Prop Slip Formula
Old 02-23-2009 | 07:43 PM
Default Prop Slip Formula
Who can tell me the formula used to determine prop slip percentage.
rssteiny is offline
Old 02-23-2009 | 07:56 PM
outlawinil's Avatar
http://www.go-fast.com/Prop_Slip_Calculator.htm
outlawinil is offline
Old 02-24-2009 | 08:16 PM
Here is another one I found.
http://www.rbbi.com/folders/prop/propcalc.htm
jeffswav is offline
Old 02-24-2009 | 08:54 PM
Mr Gadgets's Avatar
Charter Member #601
Take your prop pitch X rpm and divide by 1584 = 100% efficiency. If you figure you have 10% slip, mutiply the total by .9 and that will get you close..
play with the numbers and you can figure it out.. Or go to the sites.. This is for a 1.5:1 drive ratio.
For a 1.36 drive, divide by 1436.16....
For a 1.25 drive, divide by 1320...
Hope this helps.
Dick
Mr Gadgets is offline
Old 02-25-2009 | 12:24 PM
Using the equations you get 'calculated mph' assuming no slip. To find % slip use:
[(calculated mph - actual mph)/calculated mph] X 100 = percent slip
Where 'actual mph' is gps verified.
4mulafastech is offline
lernin-t-fly
Prop Talk
1
07-11-2005 10:59 AM
offshoreratboy
Prop Talk
12
07-03-2005 10:55 AM
wd833
Prop Talk
4
05-02-2005 05:08 PM
Rookie
5
08-12-2004 12:05 PM
jcap
11
09-27-2002 10:12 AM
