Any distributors that can run without a box??? >
Old 02-24-2009 | 11:49 AM
Default Any distributors that can run without a box???
What distributors can run by themselves and do not require a box or brain to run with it?????? Looking for the most simple/dependable set-up.........
302Sport is offline
Old 02-24-2009 | 12:38 PM
glassdave's Avatar
Neno the mind boggler
probably some variant of GM's hei maybe? Did they ever have a marine version? That would be my guess for most dependable.
08 OPA High Points Champion
glassdave is offline
Old 02-24-2009 | 01:07 PM
GM HEI or a version of it... I have a Proform Billett version that I use.. If you want to, there is a marine version I believe from MSD and or Mallory..
The one I have is vaccum adjustable and can also take adjustable springs..
Hope it helps..
Blue242 is offline
Old 02-24-2009 | 01:34 PM
Default The GM HEI marine version is called Voyager
I used a few of these systems with early EFI kits with out spark control in the mid 90s. The system comes with a coil and wire harness.
Mallory also make a nice billet version with USCG approval but I believe you would have to replace the IC module in the distributor.
MSD also make a nice billet version, but I do not believe it is USCG approved?
Brad Johnson is offline
Old 02-24-2009 | 01:57 PM
DUI, which is a GM HEI design.
http://www.performancedistributors.com/
Griff is offline
Old 02-25-2009 | 09:31 AM
Yup i have the billet HEI's from Summit in my 454's and i have been very pleased with the performance!
Car Biz is offline
Old 02-25-2009 | 10:14 AM
Buy the $125 one from auto zone. I know some guys who use these without ever failing.
1 wire for the tach and 1 wire for the ignition.
All in all done.
jeff1000man is offline
Old 02-25-2009 | 10:33 AM
fantastixvoyage's Avatar
I think I have one of those floating around the garage. if you want it to try $50.
fantastixvoyage is offline
Old 02-25-2009 | 12:34 PM
dykstra's Avatar
Msd Pro-billet
dykstra is offline
Old 02-25-2009 | 12:42 PM
You can try the Vertex
http://www.taylorvertex.com/
Shagnaz is offline
