What Size Aluminum I Beam
Old 02-24-2009 | 04:42 PM
Craney's Avatar
Default What Size Aluminum I Beam
I'm building a gantry crane to pull the engines out of my boat. I need to know what size aluminum I beam I should use for the top beam? I have 8 feet in between my 45 dergree angle.
Craney is offline
Old 02-24-2009 | 04:54 PM
jayhawk261's Avatar
That will depend on the aluminum alloy. I don't have any engineering data on aluminum. A steel 35ksi W8x10 at 8'-0" span simply supported at each end will hold a 7500 lb point load without exceeding the allowable stress of 24ksi. A W8x10x8'-0" would be relatively inexpensive, and will only weigh about 80 lbs. A W6x12 would hold a similar load and be a little shallower, but it will also be a little heavier.
jayhawk261 is offline
Old 02-24-2009 | 05:43 PM
GLH's Avatar
GLH
Get a steel beam.
Any local steel shop will be able to calculate the load.
GLH is offline
Old 02-24-2009 | 05:48 PM
Craney's Avatar
Originally Posted by GLH
Get a steel beam.
I gona use aluminum to save on weight so I can take it a part.
Craney is offline
Old 02-24-2009 | 08:11 PM
jayhawk261's Avatar
I'm not sure how much weight you'll be able to save by going with aluminum. The section will have to be deeper and beefier than its steel counterpart which means that it will not be significantly lighter. I would guess around 15% - 20% lighter max. That isn't going to make that big of a difference.
Old 02-24-2009 | 08:30 PM
Comanche3Six's Avatar
http://www.spanco.com/cm/streamfile....4-3b6622075afa
Comanche3Six is offline
Griff
Active Thunder
2
06-06-2007 06:05 PM
Vyper340
10-10-2006 09:15 PM
1BIGJIM
14
03-08-2006 02:32 AM
FASTERDAMITT
09-15-2004 09:14 AM
surfacetension
Scarab
3
01-29-2003 08:53 AM
