Go Back  Offshoreonly.com > Offshoreonly Marketplace > New Products and Member Discounts
Everlasting Sea Pump from Hardin Marine >
Old 02-24-2009 | 05:37 PM
Post Everlasting Sea Pump from Hardin Marine
Hardin Marine is offline
Old 07-14-2009 | 02:10 AM
The wait is OVER! They are here on the shelf and ready to go. Complete ALL Stainless Steel Sea Pumps and Stainless Steel Sea Pump rebuild kits! Give us a call today for more info on one of the best replacement sea pumps on the market today!
http://www.hardin-marine.com/SearchR...xact~True.aspx
Old 08-01-2009 | 12:17 PM
Rebuild kits and complete pumps with bracket and pulley now available.
Old 08-02-2009 | 08:24 AM
trips2win's Avatar
so how often will the impeller need changed still yearly?
trips2win is offline
Old 08-02-2009 | 11:50 PM
aTX427's Avatar
I could not find the rebuild kit on your website. Can you please provide the link / pricing and confirm that they are exact replacements for the plastic pump housing found in the Mercury 807151A14 kit, compatible with the 700 sci. The water pump has a boss for mounting a mechanical fuel pump into the snout.
I need to order kits tomorrow for the Emerald Cost Poker Run.
aTX427 is offline
Old 08-04-2009 | 03:43 PM
I believe this is the kit that you are looking for http://www.hardin-marine.com/detail~ID~2335.aspx
This will replace the back half of the pump just like the 807151A14 would. Don't forget your fittings! 1" NPT inlet and outlet on the backside of the pump instead of molded nipples.
Give us a call!
Old 08-10-2009 | 09:39 PM
aTX427's Avatar
Just received my rebuild kits today. Beautiful parts - can't wait to install them.
aTX427 is offline
Old 08-17-2009 | 05:00 PM
sleek1's Avatar
Will you post a pic with the pump installed? Looks like a sharp unit. I may have to buy a pair.
sleek1 is offline
Old 08-18-2009 | 08:55 AM
Elite Marine's Avatar
Great product to reduce all the headaches, issues and breakdowns due to a inferior material for a demanding part!!
Well done guys!
Let us know if we can help!!
Kirk
Elite Marine is offline
Old 08-18-2009 | 01:59 PM
As you requested....
