Trans pressure gauge sending unit >
Old 02-24-2009 | 07:59 PM
CcanDo's Avatar
Default Trans pressure gauge sending unit
Who knows how to plumb the electric pressure sending unit into the Bam 72C,driveline type ?
CcanDo is offline
Old 02-26-2009 | 12:33 PM
CcanDo's Avatar
Help!
CcanDo is offline
Old 02-26-2009 | 06:05 PM
Cat,
What is your thinking on montoring the transmission fluid pressure? As fast as your boat runs, I don't see how you will have time to look at any of the gauges!
Ben
BenPerfected is offline
Old 02-26-2009 | 06:12 PM
Leon Dereberry said he knows , give him a Jingle Jingle
Old 02-26-2009 | 09:58 PM
HotPursuit's Avatar
It goes in the 3/8 pipe plug at the top center rear of the transmission. Next to the shifter arm. The 1/8 plug near the bellhousing is the reverse pressure..
HotPursuit is offline
Old 02-26-2009 | 10:05 PM
marinetrans's Avatar
You want pressure or temp alarm,temp would be best.4versions 195* 230* 245* 290*. Think would try a 195* to be on safe side.All are 3/8 npt and close the circuit when activated.
marinetrans is offline
Old 02-26-2009 | 10:16 PM
HotPursuit's Avatar
If you go temp make sure you dont restict flow.Install a nipple so that the sensor does not go into the passage!!
Old 02-27-2009 | 08:33 AM
CcanDo's Avatar
Thanks Keith. Are you ready to run for the season?
CcanDo is offline
Old 02-27-2009 | 09:20 PM
HotPursuit's Avatar
Yes sir no major problems since august We were in it Mardi Gras day and my oldest son has my Shadow Cat.. Even thinking about putting some color on it. How you coming?? Im trying to decide on a vacuum system or just run some lines to my aircleaners.
The spring oilers are great but having trouble with the new two piece covers and breathers blowning oil out at above 5,000.
Total Seal rings with all cylinders leaking 6% or below cold.16% over on the blowers dont help!! Good to hear from u.
Old 02-28-2009 | 09:43 AM
Mbam's Avatar
Offshoreonly Advertiser
Sorry I didn't reply earlier. Yes it is the 3/8 plug kind of in the middle at the back of the trans. It’s next to the cooler outlet. Yes – make sure not to restrict the passage. We see many units come in that have a temp sender screwed right in the hole and the sensor part is almost shutting of the oil flow from the pump.
We like monitoring the pressure better than the temp. They don't get hot enough to trigger an alarm until after there is a problem. A pressure irregularity can warn of a problem in advance. If the fluid level is low the pressure will move with each bounce of the boat. After a while you get a feel for the momentary pressure drop as the cavity behind the apply piston fills when it is shifted into gear. If it starts to drop further or longer it usually is signaling a problem. Engine idle speed and fluid temperature can change this so that’s what I mean about getting a feel for it under different conditions. As it warms up the pressure at idle will be lower. Just after a hard run this is normal, but if the pressure does not come up as things cool down you should take a look at the water flow through the cooler.
Mbam is offline
