shell rotella 40w oil >
Old 03-01-2009 | 09:46 AM
Default shell rotella 40w oil
Has anyone used rotella straight 40W engine oil, I have some and not sure to use it or not. I don't use the boat below 60 degrees would this oil be recommended to use. Thanks
alecsammy is offline
Old 03-01-2009 | 05:31 PM
Hydrocruiser's Avatar
Fine to use.
Hydrocruiser is offline
Old 03-01-2009 | 06:50 PM
Make sure the oil is good and warm before pushing the sticks hard.
Ken
minxguy is offline
Old 03-02-2009 | 06:52 AM
I use the 15w40 to break in all my engines before switching to royal purple.....
ezstriper is offline
Old 03-02-2009 | 08:22 AM
It's all I've ever used in my non-roller cam motors (15-40 in car and 40w in the boat)
rdoactive is offline
Old 03-02-2009 | 08:37 AM
It is a 502 with roller lifters and rockers
Old 03-02-2009 | 12:09 PM
It's a diesel oil, so it probably exceeds most "car" oil specs. It also has a lot more detergents in it because it's made for diesels.
The reason I put non-roller cam is that oils were reformulated a few years ago, decreasing zinc content (EPA regs). Cam manufacturers started seeing a lot of flat tappet cam failures and blamed it on the reformulated oil. Rotella was not reformulated and still has a lot of zinc. Cam makers reccomend it for flat tappet motors. Your 502 will be fine.
Old 03-02-2009 | 03:57 PM
Rotella is a "goof proof oil", meaning that it also has an API SL rating, which means it can be used in gas engines.
Ken
minxguy is offline
Old 03-02-2009 | 04:00 PM
It needs the detergent because diesels are sooty. That is the reason diesel oil turns so black.
Ken
minxguy is offline
Old 03-02-2009 | 04:03 PM
Rotella has been reformulated. Zinc levels are down.
minxguy is offline
