5.5 inch fabtech lift kit for sale >
Old 03-01-2009 | 04:22 PM
Default 5.5 inch fabtech lift kit for sale
ford superduty 5.5 inch fabech lift kit front leaf spring , rear blocks ,front and rear shocks, pitman arm etc. just took it off. make an offer.
tony stamis is offline
Old 03-01-2009 | 08:18 PM
bigboat28's Avatar
What years does it fit? How old is it, and what condition? Why did you take it off? How much do you want?
bigboat28 is offline
Old 03-02-2009 | 09:31 AM
ZBODaytona's Avatar
Since the discription says leaf... I could be wrong on this...but i am pretty sure it is 97-03.
ZBODaytona is offline
Old 03-02-2009 | 09:41 AM
LapseofReason's Avatar
98-04 ?
LapseofReason is offline
Old 03-02-2009 | 10:11 AM
99-05 excursion
Old 03-02-2009 | 12:15 PM
So it's a 5.5 for a 99-05 Excursion or a 3.0 for a 98-04 super duty.
Old 03-02-2009 | 01:42 PM
bigboat28's Avatar
Lapse what do you mean, a 3 for Superduties?
Old 03-02-2009 | 03:06 PM
its 5.5 inch lift kit for an excursion if i am not mistaken the front springs are the same and the rear blocks are the same dont know if you would need anything extra to make it work on a superduty suspension on the trucks are basicly the same just bought the truck was a good deal 05 diesel ex with 40K i want the truck at stock hieght so my 3 and 6 year old can get in and out of the truck the kits in good shape vehicle was from texas and the truck has 40K on it i dont know how much of the 40 k is on the lift kit i put it out ther for someone who wants to lift there truck for aaround $600 if it will become a big issue on here i will take it to the steel scrap yard won't be the first time won't be the last when i get a chance i will get the part numbers from fab tech
Old 03-02-2009 | 03:23 PM
Superdutys are 2-2.5 inches higher than a Excursion so if it lifts an Ex. 5.5 it will only lift a Superduty 3 witch is enough to run a wide 35 or a thinner 36-37 inch tire, but a 37 would be close for any off roading.
Old 03-02-2009 | 04:09 PM
fantastixvoyage's Avatar
Tony -
thanks for the messages back and forth. you have a PM.
fantastixvoyage is offline
