6 drive owners ???
Old 03-03-2009 | 12:00 AM
Default 6 drive owners ???
when your boat is at rest how far below the waters surface is the top of your cavitation plate?? also what type of boat...no exacts neccesary just a ballpark...
thanks
Jesse James is offline
Old 03-03-2009 | 10:27 AM
Ttt
Old 03-03-2009 | 10:31 AM
thanks
Man, I would have to check. We use them to sit on when we are floating... Less than a foot I would guess. Let me look at some pics and see if I have some that show it.
40FlatDeck is offline
Old 03-03-2009 | 11:22 AM
glassdave's Avatar
Neno the mind boggler
been wondering the same thing myself. Measured many boats through last summer and came up with a pretty broad range pending hull type. Cat Vs. Vee Vs. staggered Vee etc.
08 OPA High Points Champion
glassdave is offline
Old 03-03-2009 | 11:58 AM
I should have been a little more specific......with the drives tucked all the way in and at the trailing edge of the plate......
thanks
Old 03-03-2009 | 12:50 PM
There are so many variables it would be hard to get a uniform response.
Why are you interested?
BradH is offline
Old 03-03-2009 | 01:14 PM
Sydwayz's Avatar
Forum Regulator
+1
Not sure what the purpose of the excersize may be here. At rest can very greatly even in one boat, due to passenger load, fuel load, beer/cooler load , and ballast tanks...
... not to mention one boat compared to another of same make/model that might be made of kevlar vs. C/F vs. fiberglass vs. resin; as well as traditional layup vs. vacuum bagging; etc. etc.
Then comparing different boats and types (Vs/Cats/manufacturers/lengths) would produce a WIDE spread result here.
Are you looking to develop a swim step that bolts to the cavitation plate?
Or possibly developing Hydrofoil available at West Marine and Wal*Mart to improve the performance of your VI boat?
Sydwayz is offline
Old 03-03-2009 | 01:56 PM
Coolerman's Avatar
PF Marine
the top of our drives (tie bars) are right at the top of water when just sitting. (drives about parallel with bottom of boat.
Coolerman is offline
Old 03-03-2009 | 06:56 PM
I have an idea on tight quarter, slow speed manuverability........would it be a safe bet that most are at least 8 inches below the waterline?
again not looking for exacts just a ballpark......most of our boats around here are still in dry dock...
Old 03-03-2009 | 07:01 PM
Coolerman's Avatar
PF Marine
I would say most are at least 8" below the water line
