wobble at 45mph.
Old 03-03-2009 | 08:45 PM
dykstra's Avatar
Default wobble at 45mph.
1996 4x4 454 Chevy dually. Rides fine under/over 45 mph. Soon as I hit 45 mph the truck wobbles. I think I need to have the drive shaft balanced. Any thought would appreciated.
dykstra is offline
Old 03-03-2009 | 09:31 PM
LapseofReason's Avatar
Did it just start doing it ? Balance the tires, look at the drive shaft if it lost a weight you should be able to see where it was. How old are the shocks, you may have a bad one with a tire thats out and 45 is the magic number for a bad shake, does it do it in any gear at 45 it could be a tranny problem if only in one gear. Need a little more info.
LapseofReason is offline
Old 03-03-2009 | 10:12 PM
I had the same thing ,,it was the rear CV axle on 1 side !!!!
DareDevil is offline
Old 03-04-2009 | 05:40 AM
offshoredrillin's Avatar
is it in the steering or through the body? generally drive shafts wont lose weights unless something hits it directly on the weight while spinning, it isn't impossible but improbable. depending on where it is meaning if you feel it in the wheel or through the truck, check parts that wear out quickly as in tie rod ends and ball joints also look at the rims and see if a weight is missing. also depending on whether you have oversized tires, if they are wearing properly might be time to rotate them. check with the simple things first.
offshoredrillin is offline
Old 03-04-2009 | 10:47 AM
Sea-Dated's Avatar
Yup, Rob is probably right, I had this in a Jeep and it went away when I replaced the Ball Joints and Tie Rod ends.
Sea-Dated is offline
Old 03-04-2009 | 11:28 AM
Well if it has bad ball joints and tie rod ends it sould drive like crap and eat tires.
Old 03-04-2009 | 11:30 AM
i have the same thing happening in my f350 and mine is the balljoints just to damn cold outside to change them so just gotta live with the death wobble
88scarab is offline
Old 03-04-2009 | 12:00 PM
The F350 has a straight front axle and chevy has a regular (i don't know how u call it) so in the ford it makes sence but i actually have a bad balljoint right now in the truck and u can't feel a thing,,i had the complette front end 3500BUCKS replaced and it was not it,,it was the rear CV axle ,,150 bucks done after spending 3500 bucks !!!
But now ,,like new ,,never gonna sell it !!!
The easyest way to find out is have sombody drive behind u and check the tires wile u drive at 45 MPH ,,on mine u could see it and i always thought its the rim,,changed 4 of them aswell.
And i hate to atmitt ,,but Rob is wright,,the truck shuck thru the frame not the steering.
Old 03-04-2009 | 01:56 PM
dcb
I have to ask - what kind of dually uses a constant velocity joint in the rear axle?
dcb is offline
Old 03-04-2009 | 04:06 PM
None on the axle but there are some for drive shafts.
