TRS to Bravo conversion, via Volvo transom assembly
In the Swap Shop forum, Cig92 brought up the fact that he has a Magnum hull set up for TRS drives, and converted it to Bravo I drives WITHOUT CHANGING the cut out hole for the TRS! He did this by using a Volvo transom assembly. He posted pitures of it-maybe someone could bring them over to this post (I'm computer illiterate). Cig92 claims that the Bravo I will bolt right up to the Volvo transon assembly. Cig 92 faced alot of douters-untill he posted pictures. What do you think??
If you want to read the whole thread-it is under Swap Shop, "27 Magnum hull, 3,500"
He picked up 5mph with the change!!
