Starter issues >
Starter issues
Starter issues
Old 03-08-2009 | 05:56 PM
Quinlan's Avatar
Default Starter issues
The starter on one of my 575s seems to have some issues. I seems like the battery is low but I have both on when cranking. It also feels pretty hot to the touch. When cool it cranks right up. Anybody got some ideas? Time for a new starter I am thinking.
Quinlan
Quinlan is offline
Old 03-08-2009 | 08:00 PM
if it cranks fine when cold the starter is probably is pulling high amps when warm
acaruso is offline
Old 03-08-2009 | 08:02 PM
or a bad connection
acaruso is offline
Old 03-08-2009 | 08:32 PM
johnnyboatman's Avatar
ck the ground
johnnyboatman is offline
Old 03-08-2009 | 10:26 PM
HotPursuit's Avatar
What age and how many hours.. CP performance sells some rear nice gear reduction starters..I hate starter problems.If no lose connections and good voltage I would change it..A nother problem could be bad cables meaning lots of corrosion internally.Put jumper cables from the battery to the stater if it gets better you may need new cables.. But still thinking starter!!
HotPursuit is offline
Old 03-09-2009 | 07:21 AM
Quinlan's Avatar
They are 02 575s w about 350hrs. I am leaning toward the starter also. I will do some more checking this week.
But I will say it RAN like a bat outa HELL and we had a blast!!! Put about 6 hrs on it this weekend.
Thanks for the heads up about CP.
Quinlan
Quinlan is offline
Old 03-09-2009 | 03:40 PM
Reckless32's Avatar
Rough Seas Lie Ahead
Most likely dying starter. If the connections are corroded or soething of the sort, it would either crank or it wouldn't. There's no in between. These starters hang low in the bilge ans suck up a lot of moisture from even the slightest amount of water that always seems to hang out there. This creates a lot of corrosion on the connectors, and paste like corrosion that builds up on the inside. You can sometimes take it apart yourself and simply clean it up and put back in. But the hassle of a broke starter is not worth a little savings. Cahnage the starter and run it with confidence.
Reckless32 is offline
Old 03-09-2009 | 07:14 PM
I had a starter problem that drove me nuts and it turned out to be the disconect switch.
tbanzer is offline
Old 03-12-2009 | 08:24 AM
Quinlan's Avatar
Pulled both starters yesterday. Going to replace both with new from CP performance. I am glad I know a REAL skinny Kid to get under there because my azz sure wasnt going.
Quinlan
Quinlan is offline
Old 03-12-2009 | 09:57 PM
HotPursuit's Avatar
Quinlan
Good deal make sure ya tell Mike or Rick that Keith sent you..
