m3 prochargers
Do you know if these kits will mount up to a 502 Mag EFI. All I really need is the compressor, mounting brkts and intercoolers. I will be fabbing the tubing and other stuff for a custom install. I would be buying both kits.
Do you have any pics of them in the boat??? If so could you send them to [email protected]
Thanks !!
Smitty
Thanks !!
Smitty
Baja27--
Do you know which brkts are different ?? I am being told that the main mounting is the same for all Big blocks and that the other smaller brkts might be different.
Thanks !!!
Thanks !!!
No the main bracket that holds the super charger are different on the non serpentine belt motors, but on the serpentine style I'm not 100% sure. I would give procharger a call to be sure.
