Oil leaking past intake bolts >
Old 03-08-2009 | 09:33 PM
Default Oil leaking past intake bolts
Minimal leak during cruise at 3400 RPM. Very obvious and a nuisance at RPM over 3800 RPM. I've tried Permatex brushalbe "aircraft" sealant and high temp RTV on threads and base of intake bolt heads. The 2 center intake bolts beneath the carb on the starboard side of both motors give me the most grief.
Is my crank-case ventilation not effective enough? Wrong breather system on valve covers? Wrong sealant? Any suggestions are welcomed. The motors are 509"/550hp with 200 trouble free hours. Thank you
Attached Thumbnails Oil leaking past intake bolts-p3080084-medium-.jpg   Oil leaking past intake bolts-p3080085-medium-.jpg
US MUSL is offline
Old 03-08-2009 | 10:20 PM
Grog's Avatar
It may be a fuel leak that has been pooling on a hot intake manifold for a while. Eventually, the fuel ends up looking like oil. This had me chasing an oil leak that ended up being fuel laying on the intake manifold.
....just my experience.
Good luck.
Grog is offline
Old 03-08-2009 | 11:02 PM
Good luck.
Definitely oil.
US MUSL is offline
Old 03-09-2009 | 01:45 AM
Is the oil creeping up past the threads of the bolt?
Are you sure it is not coming from the valve cover and winding up on the intake?
Young Performance is offline
Old 03-09-2009 | 08:12 AM
I believe the oil to coming past the threads. In your experience is this not possible? Maybe I should replace the valve cover gaskets or pull the covers, clean, and RTV the existing gaskets. Thanks
US MUSL is offline
Old 03-09-2009 | 10:54 AM
CcanDo's Avatar
We had a similar scenario with a 454 in a pickup - pool of oil looked identical to your picture. We re-set the Edelbrock intake and sealed the center bolts - no more oil.
CcanDo is offline
Old 03-09-2009 | 10:56 AM
CcanDo's Avatar
Ironically, it was also an Edlebrock RPM intake.
CcanDo is offline
Old 03-09-2009 | 07:41 PM
MOP
Have you checked inside the air cleaner to see if it has oil laying in the bottom, I had that problem awhile back and it dripped down the right side. I changed my crank venting and fixed the problem.
Phil
MOP is offline
Rambunctious
5
12-13-2007 09:35 PM
e8411a
4
05-09-2006 01:02 AM
drewwilliams
9
05-05-2006 07:49 PM
kathycool
12
03-22-2003 07:40 AM
RickS
05-01-2002 01:39 PM
