Switching drive ratio   ( bravo 3 to bravo 1) >
Old 03-10-2009 | 06:37 PM
Default Switching drive ratio ( bravo 3 to bravo 1)
I am the proud owner of 2001 wellcraft excalibur 24
Recently my Bravo 3 drive was stolen. I do not know what ratio it was and I want to switch to a Bravo 1 so I tried a drive which came off of a Baja, I think it was a 1.5 but I am not certain. The holeshots were terrible and I couldn't top 55 mph on GPS like I could with the B3
My old Drive serial number is OL767674 and I have the 7.4L engine s/n OL697806 my boat is 3800 pound dry weight with a V-hull similar to the larger scarab. Can anyone tell me what ratio I need to buy and also which prop should I get to at least reach 60 and still holeshot like a 24 footer.
thanks
maxfred8 is offline
Old 03-10-2009 | 06:55 PM
jeff32's Avatar
Guys! Let's welcome my long time friend FRED !!!!
I'm sure someone here has the answer or a part of the answer he is looking for.
Thanks for your help!
jeff32 is offline
Old 03-10-2009 | 07:39 PM
The 1.5 is the ratio you want.. You will have to try some different props. What was your max RPM with the 3 drive and what is it now? what prop are you running? give some more details and somoene here will dial you in.
HaxbySpeed is offline
Old 03-10-2009 | 07:52 PM
I remember hitting around 4500 with the B3 and I think that engine has a rev limiter at 4680, but with the B1 I think it was around 4300... could it be a 1.65?? the prop on the B1 was a mirage 21.
maxfred8 is offline
Old 03-10-2009 | 09:43 PM
Its possible you have a 1.36 ratio with speeds of 50-55 your slip would be between 13% and 21%. Also sometimes they put a bravo 3 deeper in the water so you may need to check propshaft depth.
diggster69 is offline
Old 03-10-2009 | 10:33 PM
thanks
Your drive OL767674 was a Bravo 3 2.00:1
Clustergear is offline
Old 03-10-2009 | 10:39 PM
jeff32's Avatar
wow! big difference! 2 vs 1.5!
What should he do to be able to use a B1? Run a 15 pitch prop?
jeff32 is offline
Old 03-10-2009 | 11:09 PM
In the Classifieds ther is a guy selling used B III's with a 2:00 gear ,,,may wanna ask him if he only sells one ?!
DareDevil is offline
Old 03-11-2009 | 07:02 AM
Also the engine ser.# you listed did come with the drive you have listed
Old 03-11-2009 | 02:04 PM
Friend of mine had the 23' 502/B1/1.50 and ran a 23P Mirage.
pi75 is offline
