can i eliminate my sea water pumps >
Old 03-11-2009 | 12:15 AM
Default can i eliminate my sea water pumps
im not running in salt water can i eliminate the sea water pumps? 502mag bravo 1
feck is offline
Old 03-11-2009 | 12:20 AM
NNNNNNNNNNOOOOOOOOOOOO !!!!! Whats gonna cool your motor ????!!!!!!!
DareDevil is offline
Old 03-11-2009 | 11:47 AM
If its not broke, don't try and fix it.
Griff is offline
Old 03-11-2009 | 12:31 PM
tfarmer's Avatar
tfarmer is offline
Old 03-11-2009 | 02:04 PM
t500hps's Avatar
21 and 42 footers
Like stated.....you can remove your water circulating pump that is on the front of the motor. You'll only run a few minutes if you remove the seawater pump off the bottom of the motor (til you blow it up).
but why remove it? HP difference is 10 maybe 15 hp and the motor was designed to have it on there.
t500hps is offline
Old 03-11-2009 | 10:08 PM
No. UNLESS, it's in a jet boat.
Darrell.
DMOORE is offline
Old 03-12-2009 | 03:16 PM
Sure you can. You'll just need a place to mount a radiator.
rdoactive is offline
Old 03-12-2009 | 07:12 PM
Just leave the tools in the tool box and step away !!
Jeff P31 is offline
Old 03-12-2009 | 09:23 PM
1BIGJIM is offline
Old 03-13-2009 | 10:19 AM
Anyone know why it works fine for some but we all don't remove it? (circulating pump that is) 10-15 FREE HP is nothing to sneeze at! Why does Mecury run them? You'd think if they could spend a few bucks on engineering and testing without a circulating pump, gain 10 free HP and save production cost, they'd do it in an instant.
bcarpman is offline
