how do can i tell if salt water trashed my motors >
Old 03-12-2009 | 01:18 AM
Default how do can i tell if salt water trashed my motors
bought a previous florida boat and i'm a little liery on the condition of the motors internally. the boats a 90 but it sat most its life, it only has 250 hrs on it. are there any good ways to check the blocks without tearing them down? any help would be great its going to be a big enough project without going through the motors
feck is offline
Old 03-12-2009 | 01:38 AM
This is something that should have been thought of and checked out BEFORE the purchase. There is no reason to worry now and nothing you can do about it anyway. If saltwater sat in the engines without being flushed, there is probably some damage. If they were flushed, then they should be fine. Even 18 years of sitting in salt air will take its toll on everything, especially electrical.
Griff is offline
Old 03-12-2009 | 09:00 AM
Salt sucks
GoFastSonic is offline
Old 03-12-2009 | 09:06 AM
First of all i would check if they turn over ,the atleast take the exhaust off and check for damage by looking into the ports.
Take the termostat off and look in there ,,if these things kind of look clean and not eaten up then u should be ok !
DareDevil is offline
Old 03-12-2009 | 09:09 AM
your first signs are usually some corrosion on any electrical connections/terminals, and bolt heads on the blocks. Down by the damper starts looking pretty bad too... if you see any of that, then it is probably further along. Pull the intake and see how nasty it looks.
eichhoma is offline
Old 03-12-2009 | 09:48 PM
I would have checked the motors before i bought it, but it was a screamin deal and the salt didnt seem to attack the boat itself and the motors look good externally, but id hate toget stranded cause i didnt checkit out.
feck is offline
Old 03-13-2009 | 01:29 PM
PatriYacht's Avatar
Cast exhaust is only good for about 5 years unless the owner flushes regularly.
PatriYacht is offline
Old 03-13-2009 | 11:57 PM
spazboz's Avatar
I guess if it was me, and I got a screamin' deal on a boat, I would prob. think there was a reason I got such an awesome deal on it. (I'm kinda paranoid that way) If it was mine, I would pop the motor's out, dismantle, inspect, and re-gasket. Replace what is necessary. You cannot put a price on peace-of-mind when you're on the water. You never know, by performing PM now, you may save thousands in mech. damage and failure later!
My .02
Nick
spazboz is offline
jeff32
01-09-2006 07:21 AM
Stormrider
03-04-2005 09:29 PM
vanderheyden
4
11-19-2003 06:30 PM
flylevel
07-18-2002 11:43 PM
Steamin Rice
05-24-2002 12:40 PM
