blowers
Old 03-14-2009 | 11:07 AM
OkieTunnel's Avatar
Default blowers
Everything I read says you cannot use a cogbelt drive in a closed engine compartment because you do not want a pop off plate in a closed engine compartment. I see cogbelt drives in closed engine compartments all the time. What gives?
OkieTunnel is offline
Old 03-14-2009 | 12:45 PM
Ask Leon!!
shark42 is offline
Old 03-14-2009 | 10:52 PM
johnnyboatman's Avatar
oh no what u got up your sleeve
johnnyboatman is offline
Old 03-15-2009 | 11:04 AM
OkieTunnel's Avatar
U guys are a lot of help!
Old 03-15-2009 | 12:23 PM
Im a giver!!
shark42 is offline
Old 03-15-2009 | 12:34 PM
about 10 million of us are using tooth belts,we can,t all be wrong.
mike tkach is offline
Old 03-15-2009 | 07:22 PM
not to be a dumb ass but whats a cogbelt?
Old 03-15-2009 | 08:10 PM
OkieTunnel's Avatar
Its what you have on the front of your blowers. My belts are 16 rib belts, they can slip if the motor backfires. (the ribs run in the same direction as the belt). Your blower belts have "teeth" that run perpendicular to the belt...They are known as cogbelts and they cant slip if the blower backfires. You should have some sort of relief plate or valve on your blower that let it "pop off" pressure if the motor backfires otherwise you might lift the blower right off the block. I think you might have had belts more like mine on your last blowers if they were 250's?
Old 03-15-2009 | 09:56 PM
o it must be your college education, to say cogbelt. most the time we normal people call it a blower belt
Old 03-15-2009 | 09:58 PM
they run them on closed engine compartments all the time, when mine backfired it just loosend the belt tensioner.
