Rotating a hatch?
Well, i had a small leak at my deck hatch and in heavy rain see it in my headliner, AND I hate how baja put the hatches backwards on the 252's. so today i removed the hatche cleaned the areas and re siliconed it all and put the hatch in forward facing. now i can crack it and get some air, or get air when camping alot easier. or when i stick my head out i can see.
Anyone else ever done this?
I also mounted my VHF antenna, and radio
I have never heard of rotating them but if it works I think that is great. Hopefully you will pick up a couple of miles per hour! LOL
We had the same issue on the 36 and had a bad seal which caused the headliner to have to be replaced under warranty.
Enjoy
Enjoy
Custom Interiors & More
We had to do that for the people that would forget to latch them, then run 80 mph down the lake, hit a wave (then) the hatch becomes a missle headed for your head
Kids are the worst for doing that.....
XT
XT
Had a 260 overnighter sea ray with a single hatch and would allway leave it crack and latched so we scooped a little breeze and it worked great. This will be great, AS LONG AS WE GOT IT SEALED. haha but it was leaking before too so...
It rained last ngiht and i did not see any new water spot or wet spots. just cleanned the headliner as best as i could Scrubbing bubbles are GREAT. even on the carpet the work wonders
Ok so still no leaks, and it worked GREAT for scooping a little air int he cabin. washed the boat, and the deck was covered with water spraying right where the eal is and nothing got inside!!!! silcone works haha
Nothing worse than water leaks to find and resolve.
Good luck
