525 water in oil? >
525 water in oil?
525 water in oil?
Old 03-17-2009 | 12:24 PM
Default 525 water in oil?
I changed the oil in my motors this weekend and the port side was light brown in color and had some white tinted goop under oil fill cap. boat has been sitting for about 4-5 months not started and last time i was there i changed the impellar. How concerned should i be? Should i run a little bit and check the oil? What is most likely cause? Has about 360 hrs had valve and lifters done on this motor last summer.
38Lightning is offline
Old 03-17-2009 | 12:31 PM
Pull the spark plugs and check for signs of water (rust) on plugs. I have seen a LOT of leaking headers.
rackster is offline
Old 03-17-2009 | 01:13 PM
Leaking headers. I would pull all your cmi headers and check them for leaks with a garden hose. might want to limit water pressure to 35 psi or so. I crapped out a 525sc with cmi headers a while back and had the same issues, brown oil and fudge ice cream in the valve train.
38fountainecman is offline
Old 03-17-2009 | 04:03 PM
tomtbone1993's Avatar
Some headers will only leak when they get hot. Since it is still early in the season I would send them back to CMI to get checked. If it is a leaky header and drops water when your engine is hot it will blow it.
I did the garden hose check and it passed, then blew my engine on the lake. Cheap insurance to have them check it.
my.02 cents
tomtbone1993 is offline
Old 03-17-2009 | 04:09 PM
can headers be repaired or do you have to purchase new ones?
Old 03-17-2009 | 04:15 PM
depends on the age and were the repair is needed.
Old 03-19-2009 | 07:24 PM
tom is right. send it in to CMI and only CMI. i had a local stroke check mine and blew a motor. Said it was fine not the case.
fountainracing65 is offline
Old 03-20-2009 | 08:32 AM
Ditto on all of the above. Take the hint on the milky oil and figure it out before you have an engine failure.
gerritm is offline
Old 03-23-2009 | 08:56 PM
It is leaking header. Pulled plug #7 and had rust then pulled headers and one side leaks. Had a leaking header on the other motor when i first bought the boat. Seems like way to many headers leak why dont someone solve this problem and if it blows enough motors would manufactur be liable?
Thanks for helping me diagnose problems.
SeaDated
12
06-19-2008 08:22 PM
UNSANE
20
04-02-2006 10:48 AM
LostinBoston
1
02-19-2006 07:00 PM
VIPER7
1
07-08-2004 07:34 PM
JJONES
1
05-20-2004 09:31 PM
