Mercury #28 Service Manaul for Bravo Units >
Old 03-18-2009 | 08:35 PM
Default Mercury #28 Service Manaul for Bravo Units
I dont have the drive numbers off hand, so does anyone know if this manual will cover a 1994 Bravo One?
#28 service manual says serial numbers 0M100000 and above.
Thanks in advance!
SmurfOnABoat is offline
Old 03-18-2009 | 08:40 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
No, there are differences in each setup that are not common between the 2.
You need manual #11. You can DL one off the net
US1 Fountain is offline
Old 03-18-2009 | 08:45 PM
thanks!
Old 03-18-2009 | 08:58 PM
Ginger or Mary Ann?
The differences are small.
The lowers may be the same. Differences will be whether yours uses a load ring or shim pack to set the prop shaft carrier bearing preload. Also the older drives verticle shaft uses a nut for the pinion gear, where as the newer drives use a bolt. 110ft lbs vs 45 ft lbs. Don't wanna mix that up.
The uppers will mainly differ on the pinion depth shimming.
Other than those 2, I think the rest is pretty straight forward.
I have the 11 on my PC if you can't find it online.
GrandLake353
Drives and Lower Units
25
03-07-2009 11:48 AM
Elite Marine
Swap Shop
1
12-18-2008 08:38 PM
blingbling
02-27-2008 08:12 PM
Alex17
1
12-13-2004 12:17 PM
imq707s
1
02-27-2002 06:15 PM
