312 fastech motor upgrade >
Old 03-19-2009 | 08:52 PM
Default 312 fastech motor upgrade
Thinking of swapping my base 7.4l mpi's out and installing 500hp efi's. anyone ever do it, any other thoughts. thanks guys
ur2slow is offline
Old 03-20-2009 | 02:50 AM
There was a time I was considering re-powering my 312.
I called the factory and spoke with them about it.
They knew of one guy who had put 500 efi's in his but I don't recall if they gave me his contact info.
Give them a call.
anasazi is offline
Old 03-20-2009 | 05:54 AM
t500hps's Avatar
21 and 42 footers
Local mechanic put them in a 312 about 3 years ago. Pulled 454mags that had 30P props (1.65 drives) and borrowed my 34P's. The boat owner loved it even though I thought the props were a little too big....they claimed the boat ran well past 80 but that was on the speedo. (probably was running 80 GPS)
t500hps is offline
Old 03-20-2009 | 09:57 AM
i think 7.4's make the 312 heavy in the a$$ end, 500's would just make it even more. Neat idea though. Would probably get it out of the hole a big quicker.
Splitdecision271 is offline
Old 03-20-2009 | 02:04 PM
t500hps's Avatar
21 and 42 footers
The 500's can't weigh much more than the 7.4......but with 190 hp more per motor it's worth it!!! I had a 312 with 502 Mags, that boat was 8,000 dry from the factory......it can handle the weight of BBC's in the back!!
t500hps is offline
Old 03-20-2009 | 09:01 PM
Mentalpause's Avatar
Pretty much the same block. There won't be a significant weight difference, as t500hps said.
With that, 80 mph on a 31 foot swim platform boat aint great.
Mentalpause is offline
Old 03-21-2009 | 07:29 PM
Talking
I just test drove a 312 with the base 7.4MPIs at Robert's today and had this very conversation regarding the 312 and bigger motors. The original BoatTest.com report of this hull with 2 X 385 HP 454 Mags they got 72.4 MPH on GPS at 5,100 RPM with 22" props and stock Bravo 1s- 1/2 fuel 3 persons. The base 7.4 310HP model we drove today got 64 MPH GPS with 2/3 fuel and 5 persons 70 degrees outside temp. Given this - The 500s or 525s will get you well into the 80's The factory runs the props deep - switch to short lower units which will raise the props and easily get you 4 to 5 mph with that change alone. I think that with a 496HO and shorty lowers you could get 80+. And yes - I bought the boat.
rubadub is offline
Old 03-21-2009 | 08:02 PM
t500hps's Avatar
21 and 42 footers
Congrats...Robert is a good as they come to deal with (I bought my 382 from him)
t500hps is offline
Old 03-21-2009 | 08:55 PM
So you think its worth doing the swap I have 400hrs and stock motors still pur but as always more power would be nice. boat is very clean just don"t know about return on $ spent down the road.
ur2slow is offline
Old 03-21-2009 | 09:03 PM
t500hps's Avatar
21 and 42 footers
your boat will be easier to sell later...but you'll never get what you put into it. (so what's the speed increase worth to YOU?)
t500hps is offline
