Perfect Pass
Look at perfectpass.com. Their newer Stargazer system is GPS based, simple installation and about 1500. It works very well. I've used this system for 15 years and loved it(was only rpm based until last year) Zero Off is new and only for use on drive by wire with P.C.M. ECM's. Give perfect pass a call and they will help you out with your application.
I have installed PP on my boat and a friends. Best $$ you can spend on a wake board boat. The new GPS based stuff is easier (no paddle wheel). Then tech support at PP is top notch, I would recommend it for sure.
