Can I Gel overtop epoxy?
Old 03-23-2009 | 08:05 AM
Default Can I Gel overtop epoxy?
Back to my screw hole question. I looked into it a bit more this weekend, and I believe I can get away with just a bit of epoxy work and gel. I know I've read on a few threads but can't remember whether or not you can apply gelcoat overtop epoxy.
Also do I need to gelcoat overtop the epoxy?
Splitdecision271 is offline
Old 03-23-2009 | 08:31 AM
Wahoo ATV's Avatar
Racer
In my experience the short answer is no. I'm sure Glassdave will explain the reason, but it has to do with to chemical compounds not bonding together.
That's why the expoxy boats are painted
Wahoo ATV is offline
Old 03-23-2009 | 09:14 AM
So what can I use instead of an epoxy, resin?
Old 03-23-2009 | 11:20 AM
glassdave's Avatar
Neno the mind boggler
no you cannot use gel over epoxy, the amine inhibits the cure out of the gel. If you are doing the repair in epoxy you will need to use a single stage urethane for color.
08 OPA High Points Champion
glassdave is offline
Old 03-23-2009 | 05:20 PM
Audiofn's Avatar
Charter Member #232
I used West Systems Epoxy to fill in my windows then primed with Durratech then gell coated. It seems to have worked very well.
Put your best foot forward!
Audiofn is offline
Old 03-23-2009 | 09:01 PM
Or "EPOGEL"
DareDevil is offline
Old 03-23-2009 | 10:22 PM
I would post pictures if I were able too. It's just a small screw hole from the old bow light. The new one only covers a portion of it so I have to fill it in with something. I'm looking for the least expensive solution, but then again I was it done correctly. Has only used a gelcoat patch kit or repair kit. My Formula dealer said that they will provide me with the gelcoat so it will hopefully match. Is it possible to fill the entire hole with gelcoat?
Old 03-23-2009 | 10:31 PM
Yes,,,buy some epogel!!!! I am not kidding its called that and its a thick gelcoat epoxy reson !!!! If its a small hole, drill it out a hair to clean it ,then tape the inside flush and fill it ,,,,,when hard sand it nicely smoth and buff it !!!!!!
Go to , www.fiberglssservices.com
Old 03-24-2009 | 10:46 PM
I see that epogel is clear, can I apply a top layer of gelcoat over top of epogel.
What's the difference between epo coat and epo gel?
BigFish
Detailing, Painting, & Fiberglass
2
11-18-2007 11:01 AM
SOX
7
08-18-2006 01:45 PM
WHOSNEXT
5
08-30-2004 07:30 PM
blue thunder
4
04-04-2004 05:22 PM
Pure Energy
02-21-2002 11:50 AM
