Best Bang for The Buck Gauge Kits!!
6K Tachometer
Oil Pressure
Water Temp
Volts
Fuel Level
Sender are sold separately. Depending on what gauges you are replacing, usually you will only need Oil Pressure and Water Temp senders to complete the setup.
105-25470 Oil Pressure Sender
105-93630 1/2" NPT Water Temp Sender
Let me know when you are ready to order and I will put a special OSO member package together for you.
Thanks,
Brad
I'm intrested in changing the VDO guages out in my 01' Formula. Would these guages work ? I would need two of everything except the volt guage which I only need one of .In addition I would also need 2 trim guages and a speedo? Do these tachs come with hour meters? I too am a OSO member. What kind of price could you work up for me on the #105-945075 stainless guage kit with the additional guages I need ?
dockrocker
02-22-2003 03:55 PM
