Corsa Quick and Quiet Exhaust on a 525 EFI >
Old 03-24-2009 | 06:11 PM
Default Corsa Quick and Quiet Exhaust on a 525 EFI
I am considering re-powering from a 502 to a 525 and am wanting to use my Corsa Quick and Quiet Exhaust. I have heard mixed reviews about this setup with the headers. Is anyone running this setup and if so have you had any problems
Tmurch3 is offline
Old 03-25-2009 | 08:00 AM
Ran them last year with no issues making about 650 HP
Attached Thumbnails Corsa Quick and Quiet Exhaust on a 525 EFI-509-big-blocks-013.jpg
brian41 is offline
Old 03-25-2009 | 08:28 AM
Where is the water mixing with the exhaust before the diverter or after it . What is the max rpm you run with them closed? Do know your cam duration I'm running emi's and with the stainless steel short riser they make for the corsa dirverters right now I'm running the dummy pipes and my dur is 228/236 @50 601 int 601 ex 112cl
Rockfish71 is offline
Old 03-25-2009 | 08:46 AM
outlawinil's Avatar
I have a set of 525 diverters that I would sell
outlawinil is offline
Old 03-25-2009 | 09:22 PM
I have the diverters on the 502, so in talking with Corsa I will have to have them modified for the 525, please give me more info on your diverters.
Tmurch3 is offline
Old 03-25-2009 | 10:12 PM
outlawinil's Avatar
Yeah, I threw the suggestion of mine for sale because your diverters from a 502 will take some modification to fit the factory headers that the 525 have on them. The 525 diverters clamp on the headers via a flange and you also have the water ports on top and bottom. May be cost effective to buy the right diverters and sell yours since yours do fit a wide range of applications
Old 03-28-2009 | 07:50 PM
It was my understanding I could send my diverters to Corsa and they would retrofit them for about $1500, but I am open to advice.
Tmurch3 is offline
Old 03-29-2009 | 06:55 AM
I will sell you a brand new set for $1700 same as pictured on my engines.
brian41 is offline
Old 03-29-2009 | 10:31 PM
outlawinil's Avatar
I'll check with CMI on what a fair price would be on mine Monday morning. They would be as close to new as you could get with only 23 engine hours at less cost than new.
Michael1
07-28-2022 08:26 PM
apexer
2
06-16-2008 01:35 PM
pol98xc6
12
01-07-2007 08:09 AM
kswest
05-21-2006 10:21 PM
JimmyBaja
4
08-11-2003 09:40 PM
