drives dont come back up!
Old 03-25-2009 | 08:23 AM
Default drives dont come back up!
I posted this in antother thread but the drives go down but none of the switches work to bring them back up. Where would the stop.limit switch/button be if it even has one? The switches dont engage anything...def. an electrical issue.
Thanksa lot
brian18330 is offline
Old 03-25-2009 | 08:54 AM
Wobble's Avatar
SORE MEMBER
do they come up with the trailer switch? if no then it sounds like a relay problem, if it's both drives then have you had any wiring unplugged? maybe you have gotten the limit switch connectors mixed up with the indicator wiring or even the low drive oil connector.
Are we talking bravo drives here? if so there is a limit switch for trim built into one side of the drive and a sender for position on the other.
Another thing I have seen is that the wedge/spacer that goes behind the stud that slides through the back of the drive is put in on the wrong side causing a big change in the amount of trim available
Wobble is offline
Old 03-25-2009 | 09:11 AM
They went up fine a month ago....none of the drive switches will work....not even the trailer one. Both relays or solenoids would go at once?
Old 03-25-2009 | 09:23 AM
Wobble's Avatar
SORE MEMBER
you will need to start at the trim switches with a circuit tester. Check all your ground connections at the dash and the trim motors.
Wobble is offline
Old 03-25-2009 | 09:57 AM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
do you hear the trim pump turn on? If so check your fluid levels.
but since both are doing the same thing Wobble is correct in the get out the test light.
Start at the switches see if you have voltage before then after the switch when it is actuated. If you do then go and check it at the pump. Have you checked any breakers or fuses in the circuit?
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Old 03-25-2009 | 10:08 AM
Brad Zastrow's Avatar
Sounds like electrical. Did you check to see if the battery is dead or very low? Twin engines have two seperate systems and wiring and you have two switches (plus the trailer switch) that do not work. What are the odds of all failing at once? I doubt it is limit switches. follow the wiring. I would start at the pumps to see if the solinoids are even being activated in the up. Look for the blue wires on the pump.
Brad Zastrow is offline
Old 03-25-2009 | 10:20 AM
Thanks alot guys......There is power to the pumps, i will check the blue one now. The pumps do not even come on when I hit the switch so I dont think its fluid. Shouldnt be a switch either if they work down, right? I'm at a loss
Old 03-25-2009 | 10:26 AM
Just short the pump conections and see if they work.
If they do then its the cable going from up switch to the pump.
DareDevil is offline
Old 03-25-2009 | 10:34 AM
I second that. There should be a round rubber 3 prong connector going into the pumps. pull that out, get a jumper wire, touch the wire from Red (hot) should be on the bottom to the green or blue. the drive should move when you jump the pins.
VetteLT193 is offline
Old 03-25-2009 | 10:47 AM
tri m switch
if its an early setup, make sure the boats in neuteral, happenned to me earlier this year on my fishing boat. trim switches wont work unless the boat is in neuteral.
himself is offline
