dome c/c
Old 03-27-2009 | 12:40 PM
Default dome c/c
what is the piston dome c,c in a stock 500hp carb motor.
rssteiny is offline
Old 03-27-2009 | 12:42 PM
my heads im using cc at 122.5
rssteiny is offline
Old 03-27-2009 | 10:08 PM
Default dome
not for certain however I think flat tops and you would have near 8.75 to 1 depending if you have stock bore
getrdunn is offline
Old 03-28-2009 | 01:57 AM
I don't know the specs on the pistons, but the stock heads are 118cc. The increase in cc is going to lower the Comp Ratio to about 8.4:1. Use a thin Cometic head gasket.
Griff is offline
KenW
Chris Craft
2
10-07-2013 04:53 PM
NOMOGOFAST
04-27-2007 03:48 PM
NOMOGOFAST
0
04-22-2007 04:36 PM
PhantomChaos
01-07-2003 03:17 PM
