timing chain cover
I have a zz502 Gen 6 in my Eliminator my stock timing chain cover can only be put on an off by lowering the oil pan. Can you buy a race cover thats quicker and easier thanks
I was on the phone with Jegs and Summit tonight they both say they have nothing but one peace covers which would be fine if I only new if the oil pan needs to drop or not . Summit or Jegs could't tell me. What we no is Gen 4,5,6 are all diffrent they make what I need in the 4,5 nothing in 6. I did find one by Comp 589.00 thats **** I,m not paying that I,ll modify a stock one if I have to.
You will need to drop the pan to get the timing cover off. I have done quite a few with out totally dropping the pan. Though you have to pull all the bolts from the front and side rails. Then "carefully" work the pan down. Do not break the rubber pan gasket. I put some small 1/2" wedges between the pan rail and block rail to keep the pan down. Now the touchy part, you have to be "very" careful with the gasket it is one piece and needs to be worked free from the bottom of the timing cover. Just don't jerk the cover of the dowels and pull it loose or you will mess up the gasket. On reinstallation do not use silicone on pan gasket. Use a thin layer of gasket maker on the bottom grove of the timing cover, let it set up a little then install and work the gasket back into the grove on the cover. Install cover with new face gasket. Bring the pan back up and reinstall all bolts. But make sure that gasket is set in the timing cover properly b-4 putting that pan up. Most people say it can't be done or will leak. But if your careful it can be done and be leak free. Did this on a Gen V three times last summer testing cams no leaks. But like I say be careful with that gasket take your time or you will be removing a pan and installing a new gasket.
This is one solution, but not certainly the least expensive. Install a Jesel belt drive. If changing cams or just adjusting the cam timing is your purpose, the belt drive is your ticket. Jesel now has a base plate made for the Gen 6 blocks.
Jesel installed on a ZZ502. Second pic shows the spacer required to clear the cam belt pulley.
Rotax has the right idea. Thats all I use is Jesel Belt Drives if the customer can handle the price of them. Now you can get the new white belt that is super stong as long as oil stays away from it, if it gets oil to it change it! Why would you be removing the cover from time to time? I could see it maybe on the dyno, after the engine is in the boat?
Just pull the cover by prying it out past dow pins then lift straight up on it so you dont break the lower lip off,, then get rid of the bottom rubber seal and use rite stuff to reseal it this stuff is good and will never leak. make it real ez to put back together.
Are the standard belts also injurerous to oil too?
