Will a block freeze with high of 50 low of 25? >
Old 03-31-2009 | 09:34 AM
Default Will a block freeze with high of 50 low of 25?
Long story short-- I purchased a boat in AZ and will be bringing it home to NE. Currently the Weather forecast is predicting highs around 45-50 Saturday and a Low of 25. I don’t think it would freeze but looking for advice from people smarter than myself.
When I say an engine block this would include oil coolers etc.
1BIGJIM is offline
Old 03-31-2009 | 10:11 AM
l think it depends on the amount of time it is in 25 degree temp.if the low was 25,it wasen,t 25 for long,you should be ok.
mike tkach is offline
Old 03-31-2009 | 10:14 AM
I think the rule is 24 degrees for 24 hours, but don't quote me on that
Perlmudder is offline
Old 03-31-2009 | 10:19 AM
Elite Marine's Avatar
No it wont.
Elite Marine is offline
Old 03-31-2009 | 10:51 AM
Sydwayz's Avatar
Forum Regulator
And you trust the weather forecasters?
Pick up 5 gallons of -50 degree AF on your way out of town. It ought to be cheap and will only take you 10 minutes to run through the engine. Even if you only 50% dilute the water in the block with the -50* AF, you are good for far colder temps that what you expect.
10 minutes of time well spent is worth days of worrying.
If you are bent on not adding antifreeze, and you are looking for a few nights of warmth, put one or two 100W droplights suspended in the bilge overnight.
Sydwayz is offline
Old 03-31-2009 | 11:00 AM
don't forget about the wind chill even if it is 25 what is it if your draggin it down the highway at 70
Hot Stepper is offline
Old 03-31-2009 | 11:06 AM
it will be fine....don't worry about it...
getchasum111 is offline
Old 03-31-2009 | 11:47 AM
hammer01's Avatar
I second this! If you are talking hauling, make sure if it has any water systems on board that they are tended to as well. The water lines for most boats are pretty cheap and the fittings are cheaper plastic. This only takes a few moments to get a bit of winterization to this system as well. I have done the lightbulb/ceramic heater treatment many times just to be safe as well(for when it is on the trailer stationary).
hammer01 is offline
Old 03-31-2009 | 12:03 PM
Dock Holiday's Avatar
Charter Member #34
NO
Dock Holiday is offline
Old 03-31-2009 | 12:06 PM
A third here! Some anti-freeze, a 5 gal pail, length of hose and some muffs. Two guys and 10 minutes, have the guy you're buying from help. Starting life with your new boat and a cracked anything is not worth it. My boat has been sitting in a heated building all winter and is fully winterized. Bad storm, loss of power = no heat = broke chit = big $ fix.
RaggedEdge is offline
