When to change impeller?
Old 04-03-2009 | 10:45 AM
Default When to change impeller?
I'm getting ready for the spring conditioning. I want to replace my raw water impeller, but should I do it before of after I start the engines up for the first time since winterizing? I've read after, this way you get the motor primed first and lessen the chance of burning up the new impeller.
Splitdecision271 is offline
Old 04-03-2009 | 10:55 AM
I would do it after. Just because the motor will probably start eaiser. But then again after you take the hoses off most of the water runs out of it anyway. If you have stariners might be a different story.
Just grease up the impeller good.
whoya is offline
Old 04-03-2009 | 11:00 AM
That's what I was thinking to do
Old 04-03-2009 | 12:41 PM
Don't use grease on the new impeller. Use liquid dishsoap.
Griff is offline
Old 04-03-2009 | 01:28 PM
What did you hear about grease? I have always used grease with no problems.
whoya is offline
Old 04-03-2009 | 01:58 PM
cigrocket's Avatar
I use the dishsoap also. Good practice
cigrocket is offline
Old 04-03-2009 | 02:03 PM
It will get stuck on the Kanutan Valve LoL
Jking
Old 04-03-2009 | 02:30 PM
Grease won't wash out and can clog up in the cooling system passages.
Griff is offline
Old 04-03-2009 | 06:23 PM
I agree this is the way I have done it, dish soap will just wash away.
jeffswav is offline
Old 04-03-2009 | 06:27 PM
What if you use to much soap will it blow bubbles out the exhaust? That would make the onlookers look a little harder
Hot Stepper is offline
