Fuel In Bilge, 1993 26 Thoroughbred, LOTS OF IT! >
Old 04-04-2009 | 05:33 PM
Question Fuel In Bilge, 1993 26 Thoroughbred, LOTS OF IT!
I went out today and filled up the boat for the first time since I bought it. WAS going to take it out for a run. Well, that thought ended when I was done filling it. I walked around the back and fuel was dripping out of the drain plug.
Are there any current or previous owner that have had this problem?
I know I should pull the floor and check the source of the leak, which I will do. But, just to help guide me in the right direction if this has happened to someone else, I would love your feedback.
Thank You,
Rodney
JusBeenBad is offline
Old 04-04-2009 | 05:34 PM
BTW, it is parked in the street, as it is not even getting close to my house or shop!
Old 04-04-2009 | 05:38 PM
Fill hose or vent line maybe?
AO31 is offline
Old 04-04-2009 | 05:40 PM
I am waiting to see how much fuel comes out before I pop the access plate in the floor. Only then will I be able to see if the cover provides access to the proper area needed for fuel lines and gauges, fittings etc.
Old 04-04-2009 | 05:43 PM
No smoking please!
AO31 is offline
Old 04-04-2009 | 05:45 PM
Smoking? I am not even going to use a cordless screw gun to pull the screws. 2 fire extinguishers will also be on hand.
Old 04-04-2009 | 05:49 PM
I am headed out the door to take a look. If there are no more posts from me soon, will someone please come and sign for the full set of gauges and drive/trim indicators that I ordered?
Old 04-04-2009 | 06:04 PM
VT32SSR's Avatar
The fuel pickup is under the rear seat. Should be a plastic acess panel there.Check to see if it is tight against the gasket.I had a 280 that leaked there when it was near full.Hope that helps.
VT32SSR is offline
Ike's Avatar
Ike
Charter Member#93
Gellner Engineering 1025"s
Ike is offline
Old 04-04-2009 | 06:54 PM
7:53 and I see a dark cloud off in the distance....
R U There??
mmareno is offline
