vynil pinstripe
Old 04-04-2009 | 08:48 PM
Default vynil pinstripe
So i bought a vynil pinstripe for my boat that measures aprox 6" wide and will span the entire lenght of the boat. I was messing around with a test piece today. I got it to stick to the area that i was applying it to, but when i went to pull the transfer tape off of the front of the stripe it was really hard to take off and messed up my entire test piece by the time i got it off.. Any ideas on how to make it easier to take off that tape? The pinstripe is kind of old and the tranfer tape is a little offcolored, looking like its been laying around in a wharehouse for some time. The glue on the tape is probably stuck really bad to the pinstripe. Any ideas on how to peel that off easily without ruining the stripe? Thanks for the input
85Baja is offline
Old 04-04-2009 | 09:31 PM
Default Tape
You can use a solution of mild soapy water and spray on transfer tape let it soak a little that should help reliese it.
redcorvetteman3 is offline
Old 04-20-2009 | 07:56 PM
Now how about getting the old pinstripe off? any tricks of the trade? Like i said before its like 6 inches wide and its stuck on there pretty good.
85Baja is offline
Old 04-20-2009 | 08:15 PM
I used a heat gun to take of my stripes.
Then i wet sanded with 1500,and buffed!
hope this helps and good luck!
stevekyp is offline
Old 04-20-2009 | 09:46 PM
glassdave's Avatar
Neno the mind boggler
old stripe is tough to work with. What color is it and what length do you need?
08 OPA High Points Champion
glassdave is offline
Old 04-20-2009 | 09:53 PM
Default stripe
I use a rotary eraser on my truck doors to remove vynal . 3m makes them at my paint store . You can also buy a right angle grinder type machine with a 2 '' wide eraser for around 500 thats what I use . Doesent ever hurt the paint only the decal.
Old 05-02-2009 | 05:57 PM
you can try spraying it with some water and see if that helps...but if it really old...it's junk...
ezstriper is offline
