Power Valve or not 540 CI
I am rebuilding my 850 DP. Running a procharger with 9lbs of boost. I was told to plug the power valve on the primaries and add 4 numbers to the primary mains. I am running 90's now and going to 94's.
Also what about getting rid of the secondary power valve to, do I need it? I have 100 mains in the secondaries now!
The carb is about 7 years old!
Thanks in advance
Thanks in advance
Think of a PV as jet that opens with decreased vacuum and increased rpm. The primary PV will open and add fuel say from 3000rpm and up because vacuum has decreased. By the time you're into the secondaries, around 4000rpms, the secondary PV will pretty much always be open anyway. Instead of using a PV, just increase the jet size.
Thanks for all the input. I am going through the carb now. I am also going to pull off the manifold and reseal it.
The power valves that came out were 3.5's and the pri jets 90, sec 100's.
