speedo not working
Old 04-07-2009 | 11:23 AM
Default speedo not working
Any ideas how to try and fix? bravo ones.
brian18330 is offline
Old 04-07-2009 | 11:25 AM
PhantomChaos's Avatar
Usually there is a rubber hose that popped off. Take a look around your drive.
PhantomChaos is offline
Old 04-07-2009 | 12:04 PM
The speedo pick up on the leading edge of the lower unit is probably plugged. Its a little notch about 4" above the bullet. The actual pick up tube could be connected to either drive.
Griff is offline
Old 04-07-2009 | 02:48 PM
Quinlan's Avatar
That was always my problem. Take the smallest drill bit you have and start w that. prob some wood in there.
Quinlan is offline
Old 04-07-2009 | 05:19 PM
johnnyboatman's Avatar
LEAVE IT PLUGGED, MAKES THE BOAT FASTER
johnnyboatman is offline
Old 04-07-2009 | 06:47 PM
Pickup tube is either plugged or cracked, and may need replacing. I had the same problem, mine was cracked, and had to splice the hose and refit together with hose barb.
07DominatorSS is offline
Old 04-07-2009 | 08:32 PM
scottw's Avatar
I agree with griff. Proabably some wood in the pitote hole.
scottw is offline
Old 04-07-2009 | 10:02 PM
OkieTunnel's Avatar
Speedo is fine...you just need more power
OkieTunnel is offline
Old 04-08-2009 | 04:54 AM
this is asuming it is not a GPS speedo
wet_rat is offline
Old 04-08-2009 | 09:37 AM
My speedo didn't work for me either....
So I switched to boxers
Flaker is offline
