Stringer replacement cost >
Old 04-08-2009 | 07:03 AM
Default Stringer replacement cost
How much should I expect to spend on having the stringers replaced on a '78 30 ft (not doing the work myself)? From the captains seats back.
bb4re is offline
Old 04-08-2009 | 11:39 AM
~ 5000 to 6000 USD !!
Fueltank needs to come out ,,floor and sofort,,then u may need new floor aswell !!!!
So my quess is 6 G's.
DareDevil is offline
Old 04-08-2009 | 03:01 PM
seltzer's Avatar
9 Times Out Of 10 You Are Gonna Need To Replace The Transom. Ouch.
seltzer is offline
Old 04-08-2009 | 06:48 PM
if the stringers and transom are wasted, it will cost what the boat is worth if you have someone else do it... your much better off to get the itchy scratchys and do it yourself. it's a lot of work, but nothing is incredibly difficult you should be able to do it yourself for under well under 1500 in materials
phragle is offline
Old 04-09-2009 | 01:04 AM
Gerhard_M's Avatar
Scarab_Kaama
Default One Benefit...
I agree! I had the same problem with my Cougar Cat: Every wood in the hull was rotten and we had to put everything out. Also 80% of the transom and the balsa core of the tunnel - rotten.
And here is the benefit:
If you do it by yourself or let do it a very good company, the hull will be stiffened maybe 30%, because Wellcraft (and I think also many other companies) didn't work very good in these years (I know this because I've redone a 1981 and 1984 Wellcraft). The cross stringers were sometimes to short to reach the forward stringers and also the bonding together was very often bad.
So you have the chance to do it better!
Gerhard
Attached Thumbnails Stringer replacement cost-20081003_001.jpg   Stringer replacement cost-20081003_003.jpg   Stringer replacement cost-20081006_002.jpg
Gerhard_M is offline
Old 04-09-2009 | 11:47 PM
J-Bonz's Avatar
Ouch!
J-Bonz is offline
Old 04-10-2009 | 07:07 AM
Default Ha!
I don't think I am THAT serious!!!
bb4re is offline
Old 04-20-2009 | 03:14 PM
Try going to this site http://www.preforms.com/ they produce stringers made out of composite material that are already covered with extra material left for "gluing" the stringer(s) in place. Do not know the cost the benifit would be a rwal time saver.
cliff_m_b is offline
Old 04-21-2009 | 07:25 AM
Default Interesting
Thanks.
bb4re is offline
