New 400sbc (408cid) f/s in NJ w/pics
'74 400cid 2bolt main block Automotive engine never in a boat!
EVERYTHING is new and fresh machine work, 0 miles and waiting to be assembled.
Stock 400 crankshaft cut .010 main/rods
.040 Speed Pro, flat top, 4 valve reliefs, 9.62:1 comp w/76cc head
Sealed Power Moly ring set
Federal Mogul cam, crank, rod bearings
Complete gasket kit
Sealed Power hi-volume, std-pressure oil pump
ATI super damper
ARP Rod bolts, main studs, balancer, flexplate, and camshaft gear bolts
Pioneer heavy duty, 168tooth, sfi flexplate
Moroso 7 quart pan with pick up tube
Machine work performed by Ron Ross at Simonek Performance
Disassembled/pressure checked/clean block
Replug block
Align bore mains
Bore & Hone to .040 w/ torque plate
Square the deck
Installed cam bearings
Resize & installed ARP rod bolts
Balance rotating assemble
Please email me
Looking to get $2000
[email protected]
Complete gasket kit
ATI super damper
Replug block
Align bore mains
Square the deck
Please email me
[email protected]
