Looking for Sea Strainer Stainless  90 high flow 1npt x 1 1/4 push on fittings >
Old 04-10-2009 | 06:11 PM
Strip Poker 388's Avatar
Rob
Question Looking for Sea Strainer Stainless 90 high flow 1npt x 1 1/4 push on fittings
I'm looking for a high flow inlet fitting for my sea strainers instead of the right angle 90's below.Ive been looking at the boat parts guys they all look restricted. Who makes them? I think I remember Fred at Trick carried them,mandrel bent style 90,wonder were he was getting them? Thanks for any suggestions ,Rob
Or is it that big of deal?
heres a pick of my strainers,These 90's I found are CP,Teague and Eddie/Rex
Attached Thumbnails Looking for Sea Strainer Stainless  90 high flow 1npt x 1 1/4 push on fittings-11-07-2-081.jpg   Looking for Sea Strainer Stainless  90 high flow 1npt x 1 1/4 push on fittings-innercooler-water-001-large-.jpg   Looking for Sea Strainer Stainless  90 high flow 1npt x 1 1/4 push on fittings-hdn-1114ss.jpg
Strip Poker 388 is offline
Old 04-10-2009 | 08:31 PM
14 apache's Avatar
You can make them MSC has the tubing it is for sanitary systems . Did a few for my boat just need to tig weld it.
14 apache is offline
Old 04-12-2009 | 02:40 PM
Rob
Talking
Ive seen them before somewhere already made up in the mandrel bent style?
I really wasn't wanting to get into manufacturing,Ill have to have the knurling done and pipe thread cut into it , then polishing it to chrome finish.
Old 04-12-2009 | 03:26 PM
STAINLESS MARINE HAS THEM !!!! Fair Pricing aswell.
Just got mine about 2 weeks ago !!!
DareDevil is offline
Old 04-13-2009 | 06:57 AM
C_Spray's Avatar
Diamond Member #001
Originally Posted by daredevil
STAINLESS MARINE HAS THEM !!!! Fair Pricing as well...
Here it is - $60
Part number 05-8888841, 1" NPT X 1 1/4" HoseE 90 Deg stainless steel.
Does Stainless sell direct? I need one as well.
C_Spray is offline
Old 04-13-2009 | 09:16 AM
Originally Posted by C_Spray
Here it is - $60
Yes they do !!!
Old 04-25-2009 | 12:34 PM
Rob
Thanks for the info.
Now I need a Water pick up. I bought 2 of Teague adjustable and its to long , and even getting them to make it shorter its still to long,They didn't want to spend anymore time on it, So now
I wonder how the Stainless marine one will work? The Teague was $299, Stainless is 1295. that seems extreme
It needs to be adjustable about 3/4 to 1 inch from the bottom of the hull.
Any suggestions????
Rob
Attached Thumbnails Looking for Sea Strainer Stainless  90 high flow 1npt x 1 1/4 push on fittings-stainless-%241289.-medium-.jpg   Looking for Sea Strainer Stainless  90 high flow 1npt x 1 1/4 push on fittings-hustler-paint-job-4-09-018-large-.jpg   Looking for Sea Strainer Stainless  90 high flow 1npt x 1 1/4 push on fittings-hustler-paint-job-4-09-022-large-.jpg
Looking for Sea Strainer Stainless  90 high flow 1npt x 1 1/4 push on fittings-hustler-paint-job-4-09-024-large-.jpg   Looking for Sea Strainer Stainless  90 high flow 1npt x 1 1/4 push on fittings-water-pick-up-40109-011-large-.jpg
Old 04-25-2009 | 12:45 PM
Rob
somebody should beable to mod or start with what Ive got and make one form it?
Attached Thumbnails Looking for Sea Strainer Stainless  90 high flow 1npt x 1 1/4 push on fittings-hustler-paint-job-4-09-030-large-.jpg   Looking for Sea Strainer Stainless  90 high flow 1npt x 1 1/4 push on fittings-picup-007-large-.jpg   Looking for Sea Strainer Stainless  90 high flow 1npt x 1 1/4 push on fittings-water-pick-up-40109-009-large-.jpg
Looking for Sea Strainer Stainless  90 high flow 1npt x 1 1/4 push on fittings-water-pick-up-40109-018-large-.jpg   Looking for Sea Strainer Stainless  90 high flow 1npt x 1 1/4 push on fittings-water-pick-up-40109-019-large-.jpg
Old 04-25-2009 | 01:16 PM
yschmidt's Avatar
I've got a buddy in western GA, that could help you out.
Shoot me an email, and I'll get you hooked up with him.
Yankey
yschmidt is offline
Old 04-25-2009 | 09:25 PM
Why dont u go straight down and cut out the drain plug into the plate's of the pickup ??????
Since they are round tubes ,,,doesn't matter !
Can u follow me ?
Also ,,cut the bend off in an angle . Otherwise ,,wayyyyyy to much water pressure !
