502 ign module
Old 04-10-2009 | 08:54 PM
Default 502 ign module
I am trying to find the correct maximum total advance of my merc 502 mags so I can choose the right ignition modules
cafeken is offline
Old 04-11-2009 | 12:59 AM
Well if it is a stock carb we would have set the timing at [36 btdc] at 3200 rpm
Boat Tech is offline
Old 04-11-2009 | 01:59 AM
Do you have modules and need to know the advance on them??? or you are looking for the best modules for your engines????
Factory full advance was set at 32*, but you can easily go 34*. The rpm for full advance varies between 3000 and 5250rpms depending on which module you have.
Griff is offline
