crane ignition box HI-6m wiring diagram >
Old 04-11-2009 | 11:00 AM
Installing a used HI-6m ignition box with its coil, it has many connectors and would like to use my harness that has two flat connectors,one for the original module and one for the original knock retard both mounted on the side of the thunderbolt dist. Also want to be able to use my knock sensor.Does anyone have a diagram for the hook-up to save me time and possibly burning up a component... Thanks Frank.
TWO YOOTS is offline
Old 04-11-2009 | 11:24 AM
The instructions are on a pdf on Crane's site
http://www.cranecams.com/pdf/90006462b.pdf
Griff is offline
Old 04-11-2009 | 10:13 PM
The Crane box won't work with your stock module OR your knock sensor.....
It WILL work with your distributer if you re-phase your rotor according to their directions....
The ONLY "knock sensor" it was designed to work with was the Anson Turbosystems unit which, from what I've found, is no longer availabe....
Doug
Boatally Insane is offline
Old 04-12-2009 | 12:16 PM
Thunderstruck's Avatar
I have the Crane HI6M modules on my boat so PM me if you have questions. I had a nice diagram of the wiring but lost it in one of the hurricanes.
Here is a pic of my drill jig to advance the rotor.
Long time cult member.
Thunderstruck is offline
Old 04-12-2009 | 12:20 PM
Here is the pic.
Attached Thumbnails crane ignition box HI-6m wiring diagram-p7160005-medium-.jpg
