Go Back  Offshoreonly.com > Owners Forum > HTM
Htm Sr 24 >
Htm Sr 24
Htm Sr 24
Old 04-12-2009 | 03:42 PM
Default Htm Sr 24
Hello All
I bought a HTM SR 24 some time ago,the boat needs a complete redone ,the formal owner was not taking care about the boat at all,as she was completely soaked with water ,I have to replace the floor in the aft compartment ,under the deck the floor is fine ,what I was wondering about is the fuel tank ,s location,is the tank always mounted under the rear seat ?
I don,t think there,s another place for a fuel tank ,but this tank was made from stainless steel ,and weight around 120 lbs empty,I can not believe that tank is the original.
Another question , some people have installed a 2 inch shorter drive ,is the prop getting enough bite ,or do they relocate the drive position ,just only to lower the engine and drive ?
I have a +- 800 hp blower engine that I wanted to use in this boat,with a Bravo 1 X 1,36:1 dual water pick up,will I gain anything if I switch to a 2 inch shorter lower unit ?
Thanks A.J
stirling is offline
Old 04-13-2009 | 04:16 PM
My fuel tanks are on each side of the boat in the back behind the side panel.What year is your boat I have a 1999 sr24.I have a std lenght drive on mine with 850 hp
dennis r is offline
Old 04-14-2009 | 11:32 AM
I believe mine is a 1998 ,any idea how big those tanks are in lenth /height wide ?
The other thing I could do is to switch to a #4 SSM that I have and don,t use anymore ,this #4 has a +- 3 1/2 inch shorter X dimension than a standard bravo,but then I need to use a gearbox /transmission for shifting the drive ,and the engine comes around 10 inches more forward ,but I was told on this forum the balance can be disturbed by doing this ...
The reason I brought up the # 4 SSM is if I wanted to go up in power I would have a stronger drive already mounted .
A guy not far from me has a set 700 CI PSI blower engines with 1300 hp ,and he want to sell me a single engine for in my HTM,but for now I need to use my own engine first.
Most people here tell me if I go to the 700 CI engine with 1300 hp ,I need to go to the hospital for a brain scan....
What do you think ?
Thx A.J
stirling is offline
Old 04-14-2009 | 07:13 PM
The tanks are 42 gallons each they are about 4 feet by 1.5 feet by 8 inchs and I would not move the motor forward the balance would be off a lot. 1300 is more then i would put in to it 1100 hp is more then enough.
dennis r is offline
Old 04-15-2009 | 07:28 AM
What do you think ?
Thx A.J
I have a 98 HTM and my gas tanks are in the back on each side of the sponsones I had a 572 with a 3.3 whipple ran 1050 on the dyno but I only ran the 940 pulley with 1.36 gears and a 32p prop and the boat did 110.It's for sale with out power in the classifieds.
raymo1979 is offline
Old 04-15-2009 | 05:09 PM
Ok Thanks Dennis ,I will make the tanks the same dimensions as yours in Aluminium,I have to replace the floor anyway ,so I,m going to glass in the construction that holds the new tanks in place .
Thx A.J
stirling is offline
