Octane of fuel recommended for 330HP 454... >
Old 04-12-2009 | 07:42 PM
Default Octane of fuel recommended for 330HP 454...
What octane fuel are you guys running in stock 330hp 454s.
Thanks.
SmurfOnABoat is offline
Old 04-12-2009 | 08:43 PM
89 should be OK
I'CE is offline
Old 04-12-2009 | 08:47 PM
Thanks.
87 should be just fine also. My 496ho's only require 87.
07DominatorSS is offline
Old 04-12-2009 | 09:51 PM
87 is the minimum but 89 should give you slightly better performance and is better for the motor all together.
2 fast 4 you is offline
Old 04-13-2009 | 02:25 AM
87 octane is minimum and running any higher octane is waste of money and will possibly hurt performance and for sure will not help performance.
Griff is offline
Old 04-13-2009 | 06:22 AM
Audiofn's Avatar
Charter Member #232
Agree
Put your best foot forward!
Audiofn is offline
Old 04-13-2009 | 11:44 AM
Keytime's Avatar
Will 93 octane hurt a 454 Mag EFI, Griff?
Keytime is offline
Old 04-13-2009 | 11:45 AM
No,,but not needet !!! 87 is just fine !!
DareDevil is offline
Old 04-13-2009 | 12:38 PM
Westcoast is offline
Old 04-13-2009 | 02:23 PM
It won't actually hurt it, but it will make your transom more black. The higher octanes won't burn as completely on an engine designed to run 87. 87 will burn the most completely and make the most power.
Griff is offline
