38 Fountain does 124MPH??
Old 04-13-2009 | 09:14 AM
jcl
This is fast for some little motors:
Cool video too!
http://www.youtube.com/watch?v=rMgXSAjGZrM
jcl is offline
Old 04-13-2009 | 09:26 AM
ApachePete's Avatar
Cheater motors.
6000 RPM
The usual Fountain crap.
ApachePete is offline
Old 04-13-2009 | 09:37 AM
Wild's Avatar
stock 700s no way
even if they are bumped up to 800hp, thats still an impressive number
Wild is offline
Old 04-13-2009 | 09:42 AM
jryan26's Avatar
http://www.offshoreonly.com/forums/f...s-believe.html
That is awesome.
jryan26 is offline
Old 04-13-2009 | 09:47 AM
AppSysCons's Avatar
No question, Fountain makes fast, very fast boats, but here are the engine specs direct from Mercury Racing, on the HP700SCi.
I saw 6000 rpm on tachs, something is not right.
HP700 SCi
SPECIFICATIONS
Horsepower 700 (522 kW)
Full Throttle RPM Range 4800-5200
Displacement Liter/C.I.D. 8.2/502
Bore (in/mm) 4.47/113
Stroke (in/mm) 4.00/102
Compression Ratio 7.5:1
Cylinders V-8
Alternator (amp/watt) 90/1269
Ignition Type PCM Distributorless
Fuel System Sequential Fuel Injection
Fuel Requirements 89 Posted Octane (R+M)/2, (95 RON) International
Transmission Mercury Racing dry-sump
Drive Unit NXT¹® or NXT¹® SSM*
Gear Ratio NXT¹®, 1.61:1, 1.50:1, 1.35:1,1.24:1 or 1.15:1 or NXT¹® SSM*
Length (in/mm) 35.7/907
(Transom mount to front of engine)
Width (in/mm) 33/838
Height (in/mm) 27.9/709
Weight (lbs/kg) 1548/702
Warranty 1-Year Limited for Recreational Boating
AppSysCons is offline
Old 04-13-2009 | 09:51 AM
Brad Zastrow's Avatar
Mercury racing 700 sci limiters are 5450 rpm. There is a lot you can do to the 700 and 850 and the 1075 engines if you can get into the box and pulley changes.
Brad Zastrow is offline
Old 04-13-2009 | 09:53 AM
My buddy went for a ride on the OL 42 Super lego and he asked us if the 700s should spin 6200.
Pro1 is offline
Old 04-13-2009 | 10:25 AM
ApachePete's Avatar
Can a GPS speedo be tampered with, too?
Old 04-13-2009 | 10:35 AM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
There might be more there than meets the eye, but, the 700 NXT engine makes 785 hp at the crank and MERCURY also told me that they have 720 at the propeller shaft with this package.
So, I think everyone's base line is off here. 800 is low.
Rik is offline
Old 04-13-2009 | 10:44 AM
How does it go that fast? 10mph more than normal puls runnin 6000 rs lets just find out the truth and not post rummors
Detail Toyz is offline
