Go Back  Offshoreonly.com > Owners Forum > Black Thunder
Props spinning in or out >
Old 04-13-2009 | 05:16 PM
Default Props spinning in or out
Just curious as to which direction most of the Black Thunders are spinning their props. I understand the IN/OUT dilemma but just seein which works best on these particular boats. Thanks
endeavor1 is offline
Old 04-13-2009 | 07:20 PM
excursion's Avatar
The props should be spinning OUT .
Spinning in gives you nothing but stern lift and you loose almost all your docking abilities.
excursion is offline
Old 04-13-2009 | 07:47 PM
BT's do not normally need stern lift. Hulls do the work very well of lifting the stern. Mine are spinning out.
THLWL is offline
Old 04-13-2009 | 08:42 PM
Thanks guys, just wasnt sure, had staggered stepped fountains before this boat and the props always turned in. Is there a bunch of Black Thunders running BMAXs? Bob Jenkins has told me to leave them on the boat as he knows that more HP will be coming for me soon.... lol They just seem like overkill
Old 04-13-2009 | 09:57 PM
Go to the APACHE section ,,,TRES MARTIN proofed me wrong and its vise versa ,,spining in gives u bow lift ,,NOT STERN LIFT !!!!!!!
DareDevil is offline
Old 04-14-2009 | 08:44 AM
excursion's Avatar
Well i have done both with the BT and in is nothing but a cluster f,
Old 04-14-2009 | 01:52 PM
Coolerman's Avatar
PF Marine
side by side engine configurations on 46's BT's need them spinning out. It's easier to dock, and they are more stable. Spinning out also creates transom lift which the BT's actually need. And if you haven't had any issues with the Bmaxes, keep them on!
Coolerman is offline
Old 04-14-2009 | 09:17 PM
What power are you running?
waconda is offline
Old 04-15-2009 | 09:51 AM
500EFIs .... have one whipple for it and waiting to purchase the next. Hoping to see an honest 600hp with some reliablity
Old 04-15-2009 | 02:53 PM
Veteran: Air Force
Veteran: National Guard
Saxman which way are you with the staggered setup?
Spiker is offline
