Engine Dyno Tuned   COST?  Don't want to overpay for service >
Old 04-14-2009 | 10:12 PM
Default Engine Dyno Tuned COST? Don't want to overpay for service
New to boats and have not gotten a boat dyno'd yet. My cars were only about $400 but I'm assuming that's a paltry sum compared to a boat. I know with cars that some shops I've run across will charge way more than others. So what is a reasonable price for my single engine? (carbed 502 roller tuned with a new blower)
Also, what do most performance shops charge per hour for service?
thanks
hotstang46 is offline
Old 04-14-2009 | 10:50 PM
thanks
Most shops charge around 100+ per hour ,,but all of them are worth the money .LOL
Dyno is ~ 400-600 dollars if u bring the engine there !!!
DareDevil is offline
Old 04-15-2009 | 12:11 AM
fireboatpilot's Avatar
RIPSTA Racing Team
Hey Scott, I just had one of my engines rebuilt and was told the best way to break in an engine is to do it on a dyno? To vary the rpm and load ect? I was told $500. per day on the dyno and could take them 2-3 days time to tune, check, test, run, break in ect. Does this sound right to you? I didn't want to drop the new engine in and break it in on the water. Not being able to monitor and hear what's going on. Your thoughts?
fireboatpilot is offline
Old 04-15-2009 | 08:30 AM
I just dyno tuned one last week. $500 plus tax and $350 for the tuner(Thanks Ed). WAAAAAAY easier on the stand than in the boat!
kennyo is offline
Old 04-15-2009 | 08:41 AM
I'm getting quotes at $600 per engine in TX, a blower would probobly be more
TexomaPowerboater is offline
Old 04-15-2009 | 09:06 AM
so about 500-600 for the actual dyno tune.
then about how many hours can I expect to remove and reinstall my single engine?
I really appreciate the responses guys. It's hard having not done this before and walking into a shop. I'm always wondering if I'm being overcharged (bad experience before when I was young and getting work done to my first car)
thanks again
Old 04-15-2009 | 09:21 AM
Jammin''s Avatar
By the time they got done with my engines over two days, one quite long, it was about $1500. Well worth it. Issues got resolved that would have driven me crazy on the water.
Jammin' is offline
Old 04-15-2009 | 03:02 PM
Wobble's Avatar
SORE MEMBER
400-600 around Houston for basic setup assuming thats where you got your motor built, that's about 3-4 hours in the cell.
A basic tune to me is timing and timing curve, jetting, carb spacers and or carbs. 15-20 pulls. Running the valves one time.
It is well worth your time to have a plan before you start.
Get your jets, carb spacers, distributor springs, air cleaners and anything else you want to try lined up.
Get your basic setup and adjustments then try a few variations. The engine builder and or dyno guy will normally have a real good idea what might work so do your research and dont leave until your happy even if that means an extra couple hundred.
Get your dyno sheets printed and on a disc, be sure that the correction factors show.
you may need to find a water pump and pulley/belt in order to make your setup work on the dyno.
Wobble is offline
Old 04-15-2009 | 05:16 PM
I had mine done last year by Tyler Crockett it was in the same ballpark price as the others although mine is fuel injected and blown. The tune took it from about 650 hp on the first pull to over 720 hp when we were done.
RBeyer is offline
Old 04-15-2009 | 07:53 PM
MER Performance's Avatar
I charge $600.00 per engine, but it's my build and I have to tune it. The second engine takes alittle less time since you already have a baseline. If someone else builds the engine and brings it to you how do you know it's not going to mess-up your dyno room. If you build engines matched correctly the tune-up should be equal for both.
MER Performance is offline
