Any lift truck mechanics on board?
Offshoreonly Advertiser
This is kind of boat related, we use the lift truck to move the boat. Is OK right?
We are just finishing up a brake job on our 9000lb Mitsubishi & I have a question about adjusting the wheel bearings. In my experience (which is limited to regular automotive and trailer stuff) the bearings are tightened (by hand) to seat them, spin the wheel a few times, tighten again and then back off to zero pre-load or slightly further as needed to align cotter pin(or other lock device).
Is this the same with the larger full-float axles or do the bearings actually get some pre-load?
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
Witha heavy drum like that it's important to torque to about 50ft/lbs while rotating, then back it off and set as you describe. This centers and seats the bearings. This is true for just about any kind
Marc,
We're a Toyota forklift dealer, but, I do have
a repair manual that covers certain Mitsubishi
forklifts ranging from 2000-8000# capacity.
It says to tighten the nut to 101 ft/lbs, back the
nut off 80* rotate the drum and check the preload....preload
is 4.7-7.6 ft/lbs.
I would think your unit should be close to what this requires.
is 4.7-7.6 ft/lbs.
That is great, kind of what I expected. I'll go with that.
BIG THANKS to both of you!!
Marc
www.go-fast.com
www.bammarine.com
Marc
www.go-fast.com
www.bammarine.com
