imco 2" shorty lower how does it help or not >
Old 04-21-2009 | 11:48 AM
Default imco 2" shorty lower how does it help or not
27 checkmate 500hp good or bad bought boat with 2" shorty boat runs 65gps with 24bravo it should go faster
checkmate 500 is offline
Old 04-21-2009 | 12:13 PM
What rpm??
What drive ratio???
How far is the propshaft below the bottom????
Does it have trouble lifting the bow when trimming up???
Griff is online now
Old 04-21-2009 | 12:26 PM
1.5 ratio 5400rpms at 65mph the bow does not lift much, when I trim up rpms go up with not much speed gain, like a normal drive very large rooster tail
Old 04-21-2009 | 01:03 PM
Ran-Dom 32's Avatar
may actually be hurting your top speed, they only sure fire way to prove it to try a 1 or 2" spacer, which will give you more bow lift
Ran-Dom 32 is offline
Old 04-21-2009 | 02:55 PM
What prop are you using? Is it a bow lifting prop or stern lifting prop? I normally use a Mirage plus (bow lifter). I borrowed a friends Hydromotive 4 blade (stern lifter) and mine did the same thing you are talking about.
jeffswav is offline
Old 04-22-2009 | 01:30 AM
The shorty is definately hurting your performance. Try 1" to 2" spacers to lower the propshaft as Random said. The Bravo prop is not the problem.
Griff is online now
