Lunati Cam "check it out"
I realize Bob is the Cam Man however I must have missed this one with earlier cam searches. Let me know your thoughts. Exhaust is gils with high risers. Reversion???
Voodoo Retro Fit Hyd Roller Cam - Chevrolet Big Block 282/290
Product Description
Lunati's Voodoo series of Hydraulic Roller camshafts deliver more area under the curve than any other series of Hydraulic camshafts. This means more throttle response, quicker acceleration, more vacuum, better efficiency, combined with maximum horsepower and torque!
Hydraulic roller, lopey idle. High performance street cam. Likes upgraded intake, carburetor and exhaust system. Needs 2800 RPM or better stall speed converter, 9.75:1 compression ratio and 3.55-3.73 rear gears.
Advertised Duration (Int/Exh): 282/290
Duration @ .050 (Int/Exh): 231/239
Gross Valve Lift (Int/Exh): .600/.600
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 2200-5800
Includes: Cam Only
Part Number: 60212
Jobber Price: $337.00
Cam Spec Card Print
60212 VDBC-282 CHEVROLET 396-454 2200-5800 110 5.5 9.5 53.5 41.5 106 4 .600 .600 1.7 1.7 .000 .000 N/A 231 239 282 290
http://www.lunatipower.com/Product.aspx?id=2156&gid=289
Product Description
LSA/ICL: 110/106
Includes: Cam Only
Part Number: 60212
Cam Spec Card Print
