Needed...Whipple or vortech supercharger >
Old 04-26-2009 | 12:30 AM
Default Needed...Whipple or vortech supercharger
Looking for a whipple or Vortech for a 454/502 Mag application whats avail..
xtreme 1 is offline
Old 04-26-2009 | 11:19 AM
Smitty's Avatar
Check the classifieds here. Guy is selling complete kits.
Smitty is offline
Old 04-26-2009 | 01:49 PM
The only thing I found was an old side mount.....or did I miss something??
xtreme 1 is offline
Old 04-26-2009 | 04:12 PM
Smitty's Avatar
That's the one. If you have a stock 502, it will make around 550 hp. If you modify engine like I did , you can see more like 750 with that little blower. If you only have a single, I would snatch it up, have it custom tuned and be rockin' for under 3 grand for 550 hp.
Smitty is offline
Old 04-26-2009 | 05:20 PM
Smitty, what modifications did you do to your engine? I have a stock 502 Mag an I am putting a Vortec Supercharger on it in the next couple weeks. I have the engine out of the boat now because I had to replace the transom. I have Gil manifolds and 4 inch risers / pipes. I also have a MSD Ignition system (ignition, rev limiter, coil, distributer and wires. Any ideas? I thought I would put a fresh set of head gaskets in it since engine is out and I am adding the Vortec?
Sorry xtreme 1 I didnt mean to steal your thread just looking for options. We have a couple guys around here that swear by Vortec for what its worth?
baja_brian is offline
Old 04-26-2009 | 10:45 PM
its all good then again this is a q&a forum...I too like the vortech the only down side for me is that I really cant afford the forward clearance..But...If thats the only way then well I guess its gonna get alittle snug in the back seat Who cares I dont sit there anyway
xtreme 1 is offline
Old 04-27-2009 | 12:29 PM
Smitty's Avatar
Here's what I would do:
1. Definitely change the head gaskets and buy good ones like cometic or Fel-Pro MLS
2. Change your valve springs to new ones since the heads are off.
3. Since you are staying with the iron heads, polish the combustion chambers in the head. This will eliminate a place for detonation to start which will kill a piston. Be careful so you don't remove too much material as it will change the cc's of the head.
4. If you can afford it also change from head bolts to studs from ARP. Just a little more insurance to keep the heads from lifting.
5. If the heads need a valve job, have it changed to a single angle as this will allow for maximum heat transfer when valve is on the seat. Loss in performance from this mod is neglible in a boat app.
Good Luck !!!
Smitty is offline
Old 04-27-2009 | 12:30 PM
Smitty's Avatar
Is Vortech still selling new kits for marine apps??? I thought they stopped ???
Smitty is offline
